ichavarria Posted May 31, 2016 Share Posted May 31, 2016 Hi, i'm want to import the code (or description) from csv file (X,Y,Code) on the coordinates of each point. I can do it in excel, but i'm looking for a easy way. The layer could be current, height 2, and rotation 0. I can change this properties later, so no problem about it. Please excuse my limited English, corrections are welcome. Many thanks in advance. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 31, 2016 Share Posted May 31, 2016 Very quickly written: (defun c:txtin ( / csv des ins lst str ) (if (and (setq csv (getfiled "Select CSV File" "" "*" 0)) (setq des (open csv "r")) ) (progn (while (setq str (read-line des)) (while (vl-string-position 44 str) (setq str (vl-string-subst "\"\"" "," str)) ) (if (and (setq lst (read (strcat "(\"" str "\")"))) (setq ins (mapcar 'distof lst '(2 2))) (caddr lst) ) (entmake (list '(0 . "TEXT") '(40 . 2.0) (cons 10 ins) (cons 1 (caddr lst)))) ) ) (close des) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
ichavarria Posted May 31, 2016 Author Share Posted May 31, 2016 Thank you very much Lee Mac It is exactly what I had been long looking for. Many thanks for your help. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 31, 2016 Share Posted May 31, 2016 You're welcome - glad it helps. Quote Link to comment Share on other sites More sharing options...
