zefreestijl Posted May 31, 2016 Share Posted May 31, 2016 A while statement would be what you want... (defun c:BND (/ pt) (while (setq pt (getpoint "\nPick internal point: ")) (command "_.-boundary" "_a" "_i" "_n" "" "" "_non" pt "") ) (princ) ) Thread: Boundary Creation Lisp- a request HI, I just learned how to create boundary smoothly from the above post. is there a way to create boundary by the coordinates of selected Texts? Thanks! Quote Link to comment Share on other sites More sharing options...
ziele_o2k Posted May 31, 2016 Share Posted May 31, 2016 Something like that? (defun c:BNDTXT (/ pt) (while (setq pt (cdr (assoc 10 (entget (ssname(ssget "_+.:E:S" '((0 . "TEXT"))) 0))))) (command "_.-boundary" "_a" "_i" "_n" "" "" "_non" pt "") ) (princ) ) Quote Link to comment Share on other sites More sharing options...
ziele_o2k Posted May 31, 2016 Share Posted May 31, 2016 Or like that? (defun c:BNDTXTMULTIPLE (/ pt) (if (setq ss (ssget '((0 . "TEXT")))) (repeat (setq in (sslength ss)) (setq pt (cdr (assoc 10 (entget (ssname ss (setq in (1- in))))))) (command "_.-boundary" "_a" "_i" "_n" "" "" "_non" pt "") ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
tombu Posted May 31, 2016 Share Posted May 31, 2016 Try: ;;; 2000+ version ;;; Tbox.lsp - Draws boxes around Text, Mtext, Attributes & Dimension Text. ;;; BY: TOM BEAUFORD ;;; tombu@leoncountyfl.gov ;;; LEON COUNTY PUBLIC WORKS ENGINEERING SECTION ;======================================================================== (defun c:tbox (/ *ERROR* thisdrawing EnTyp ENT EnPt SubE SEnTyp Blk BOBJ elist EOBJ ELA rot of ps AtPt ss tb of ll lr ul ur) (vl-load-com) (defun *ERROR* (err) ; define local handler (princ) );; "" is the same message you get when exiting an AutoCAD command. (setq thisdrawing (vla-get-activedocument (vlax-get-acad-object))) (setvar "cmdecho" 0) (setq ENT "Something") (while ENT (while(not(or(= EnTyp "ATTRIB")(= EnTyp "ATTDEF")(= EnTyp "TEXT")(= EnTyp "MTEXT"))) (if(not(= EnTyp nil))(prompt "\nEntity Selected not an Attribute or Text")) (if(setq ENT (entsel "\nSelect Attribute or Text: ")) (setq EnTyp (cdr (assoc 0 (entget (car ENT)))) EnPt (cadr ENT) ENT (car ENT) ; Entity name SubE (car (nentselp "" EnPt)) ; SubEntity SEnTyp (cdr (assoc 0 (entget SubE))) ; SubEntity type ); setq (setq ENT nil EnTyp nil SEnTyp nil) ); if (cond ((= SEnTyp "ATTRIB")(setq ENT SubE EnTyp SEnTyp SubE nil SEnTyp nil)) ((= EnTyp "DIMENSION") (progn (princ "\nEnTyp = Dimension.") (setq Blk ENT ; Parent entity name ENT SubE BOBJ (vlax-ename->vla-object Blk) ; Entity object EnTyp SEnTyp SubE nil SEnTyp nil ); setq ); progn ); EnTyp = "DIMENSION" (ENT(princ "\nEnTyp is not a Dimension, Insert or Attribute.")) ); cond (setq elist (entget ENT); Entity list ) (setq EOBJ (vlax-ename->vla-object ENT) ; Entity object ELA (getvar "clayer") ; Object layer );;setq ; (if Blk(vlax-dump-object (vlax-ename->vla-object Blk))) ; (vlax-dump-object EOBJ) ; List object properties (if(acet-layer-locked ELA) ; If object layer's locked (progn (prompt(strcat "Current Layer \"" ELA "\" is Locked.")) (setq EnTyp nil) ; continue while loop ) ) );;while (setq rot (vlax-get-property EOBJ 'Rotation) of (vlax-get-property EOBJ 'Height) ps (vlax-safearray->list(vlax-variant-value (vlax-get-property EOBJ 'InsertionPoint))) ) (vla-startundomark thisdrawing) (cond ((= EnTyp "MTEXT") (progn (if Blk (setq of (*(vlax-get-property BOBJ 'TextGap)2))) (setq AtPt (vlax-get-property EOBJ 'AttachmentPoint)) (cond ((or(= 1 AtPt)(= 4 AtPt)(= 7 AtPt))(setq ps (polar ps(+ rot PI)(/ of 2)))) ((or(= 2 AtPt)(= 5 AtPt)(= 8 AtPt)) (setq ps (polar ps(+ rot PI)(/ (+ (cdr(assoc 42 elist))of) 2))) ) ((or(= 3 AtPt)(= 6 AtPt)(= 9 AtPt)) (setq ps (polar ps(+ rot PI)(+ (cdr(assoc 42 elist))(/ of 2)))) ) ) (cond ((or(= 1 AtPt)(= 2 AtPt)(= 3 AtPt))(setq ps (polar ps(+ rot(/ PI 2))(/ of 2)))) ((or(= 4 AtPt)(= 5 AtPt)(= 6 AtPt)) (setq ps (polar ps(+ rot(/ PI 2))(/ (+ (cdr(assoc 43 elist))of) 2))) ) ((or(= 7 AtPt)(= 8 AtPt)(= 9 AtPt)) (setq ps (polar ps(+ rot(/ PI 2))(+ (cdr(assoc 43 elist))(/ of 2)))) ) ) (setq lr (polar ps rot (+ (cdr(assoc 42 elist))of)) ul (polar ps (- rot(/ PI 2))(+ (cdr(assoc 43 elist))of)) ur (polar lr (- rot(/ PI 2))(+ (cdr(assoc 43 elist))of)) ) (vl-cmdf "pline" "non" ps "non" ul "non" ur "non" lr "c") ;Drawn Box ); progn ); EnTyp = "MTEXT" ((or(= EnTyp "ATTRIB")(= EnTyp "TEXT")) (progn (if(= EnTyp "ATTRIB") (setq elist(subst(cons 73 (cdr(assoc 74 elist)))(assoc 74 elist)elist) elist(subst(cons 0 "TEXT")(assoc 0 elist)elist) ) ); if (vl-cmdf "ucs" "OBject" ENT) (setq tb (textbox elist) ll (list(-(car(car tb))(/ of 6))(-(cadr(car tb))(/ of 6))) ur (list(+(car(cadr tb))(/ of 6))(+(cadr(cadr tb))(/ of 6))) ) (vl-cmdf "rectang" "non" ll "non" ur) ;Drawn Box (vl-cmdf "ucs" "p") ); progn ); EnTyp = "ATTRIB" or "TEXT" ); cond (setq Box (vlax-ename->vla-object (entlast))) (vl-catch-all-apply 'vla-put-Linetype (list Box "CONTINUOUS")) (vl-catch-all-apply 'vla-put-ConstantWidth (list Box (/ of 20))) (setq EnTyp nil SEnTyp nil) (vla-endundomark thisdrawing) ); while (princ) ); defun Quote Link to comment Share on other sites More sharing options...
zefreestijl Posted May 31, 2016 Author Share Posted May 31, 2016 Or like that? (defun c:BNDTXTMULTIPLE (/ pt) (if (setq ss (ssget '((0 . "TEXT")))) (repeat (setq in (sslength ss)) (setq pt (cdr (assoc 10 (entget (ssname ss (setq in (1- in))))))) (command "_.-boundary" "_a" "_i" "_n" "" "" "_non" pt "") ) ) (princ) ) Yes! It works! Thank you so much!! Now I can use this lisp to find a boundary of structural slabs, Thanks again. Quote Link to comment Share on other sites More sharing options...
zefreestijl Posted May 31, 2016 Author Share Posted May 31, 2016 Try:;;; 2000+ version ;;; Tbox.lsp - Draws boxes around Text, Mtext, Attributes & Dimension Text. ;;; BY: TOM BEAUFORD ;;; tombu@leoncountyfl.gov ;;; LEON COUNTY PUBLIC WORKS ENGINEERING SECTION ;======================================================================== (defun c:tbox (/ *ERROR* thisdrawing EnTyp ENT EnPt SubE SEnTyp Blk BOBJ elist EOBJ ELA rot of ps AtPt ss tb of ll lr ul ur) (vl-load-com) (defun *ERROR* (err) ; define local handler (princ) );; "" is the same message you get when exiting an AutoCAD command. (setq thisdrawing (vla-get-activedocument (vlax-get-acad-object))) (setvar "cmdecho" 0) (setq ENT "Something") (while ENT (while(not(or(= EnTyp "ATTRIB")(= EnTyp "ATTDEF")(= EnTyp "TEXT")(= EnTyp "MTEXT"))) (if(not(= EnTyp nil))(prompt "\nEntity Selected not an Attribute or Text")) (if(setq ENT (entsel "\nSelect Attribute or Text: ")) (setq EnTyp (cdr (assoc 0 (entget (car ENT)))) EnPt (cadr ENT) ENT (car ENT) ; Entity name SubE (car (nentselp "" EnPt)) ; SubEntity SEnTyp (cdr (assoc 0 (entget SubE))) ; SubEntity type ); setq (setq ENT nil EnTyp nil SEnTyp nil) ); if (cond ((= SEnTyp "ATTRIB")(setq ENT SubE EnTyp SEnTyp SubE nil SEnTyp nil)) ((= EnTyp "DIMENSION") (progn (princ "\nEnTyp = Dimension.") (setq Blk ENT ; Parent entity name ENT SubE BOBJ (vlax-ename->vla-object Blk) ; Entity object EnTyp SEnTyp SubE nil SEnTyp nil ); setq ); progn ); EnTyp = "DIMENSION" (ENT(princ "\nEnTyp is not a Dimension, Insert or Attribute.")) ); cond (setq elist (entget ENT); Entity list ) (setq EOBJ (vlax-ename->vla-object ENT) ; Entity object ELA (getvar "clayer") ; Object layer );;setq ; (if Blk(vlax-dump-object (vlax-ename->vla-object Blk))) ; (vlax-dump-object EOBJ) ; List object properties (if(acet-layer-locked ELA) ; If object layer's locked (progn (prompt(strcat "Current Layer \"" ELA "\" is Locked.")) (setq EnTyp nil) ; continue while loop ) ) );;while (setq rot (vlax-get-property EOBJ 'Rotation) of (vlax-get-property EOBJ 'Height) ps (vlax-safearray->list(vlax-variant-value (vlax-get-property EOBJ 'InsertionPoint))) ) (vla-startundomark thisdrawing) (cond ((= EnTyp "MTEXT") (progn (if Blk (setq of (*(vlax-get-property BOBJ 'TextGap)2))) (setq AtPt (vlax-get-property EOBJ 'AttachmentPoint)) (cond ((or(= 1 AtPt)(= 4 AtPt)(= 7 AtPt))(setq ps (polar ps(+ rot PI)(/ of 2)))) ((or(= 2 AtPt)(= 5 AtPt)(= 8 AtPt)) (setq ps (polar ps(+ rot PI)(/ (+ (cdr(assoc 42 elist))of) 2))) ) ((or(= 3 AtPt)(= 6 AtPt)(= 9 AtPt)) (setq ps (polar ps(+ rot PI)(+ (cdr(assoc 42 elist))(/ of 2)))) ) ) (cond ((or(= 1 AtPt)(= 2 AtPt)(= 3 AtPt))(setq ps (polar ps(+ rot(/ PI 2))(/ of 2)))) ((or(= 4 AtPt)(= 5 AtPt)(= 6 AtPt)) (setq ps (polar ps(+ rot(/ PI 2))(/ (+ (cdr(assoc 43 elist))of) 2))) ) ((or(= 7 AtPt)(= 8 AtPt)(= 9 AtPt)) (setq ps (polar ps(+ rot(/ PI 2))(+ (cdr(assoc 43 elist))(/ of 2)))) ) ) (setq lr (polar ps rot (+ (cdr(assoc 42 elist))of)) ul (polar ps (- rot(/ PI 2))(+ (cdr(assoc 43 elist))of)) ur (polar lr (- rot(/ PI 2))(+ (cdr(assoc 43 elist))of)) ) (vl-cmdf "pline" "non" ps "non" ul "non" ur "non" lr "c") ;Drawn Box ); progn ); EnTyp = "MTEXT" ((or(= EnTyp "ATTRIB")(= EnTyp "TEXT")) (progn (if(= EnTyp "ATTRIB") (setq elist(subst(cons 73 (cdr(assoc 74 elist)))(assoc 74 elist)elist) elist(subst(cons 0 "TEXT")(assoc 0 elist)elist) ) ); if (vl-cmdf "ucs" "OBject" ENT) (setq tb (textbox elist) ll (list(-(car(car tb))(/ of 6))(-(cadr(car tb))(/ of 6))) ur (list(+(car(cadr tb))(/ of 6))(+(cadr(cadr tb))(/ of 6))) ) (vl-cmdf "rectang" "non" ll "non" ur) ;Drawn Box (vl-cmdf "ucs" "p") ); progn ); EnTyp = "ATTRIB" or "TEXT" ); cond (setq Box (vlax-ename->vla-object (entlast))) (vl-catch-all-apply 'vla-put-Linetype (list Box "CONTINUOUS")) (vl-catch-all-apply 'vla-put-ConstantWidth (list Box (/ of 20))) (setq EnTyp nil SEnTyp nil) (vla-endundomark thisdrawing) ); while (princ) ); defun This one works, too! Thank you for your help! Quote Link to comment Share on other sites More sharing options...
