Hi All,
I'm looking to see if there is a Lisp out there that as you copy a block in a drawing the first attribute with change in increments of 1 I.e.
P1 P2 P3
Thickness " " " "
Material " " " "
(1) " " " "
P1 Would be the attribute that changes every time it gets copied.
Thanks
Brain
GRR,
Thanks for the reply, I use that lisp all of time but never noticed the block use in it. Thanks to Lee Mac and his wonderful Lisp...
GRR,
Don't worry, even I had situations like yours. Example:
I was looking for a lisp that puts blocks on a 3Dpolyline, and later I've found that his PTMANAGER supports this (which I use often) !
Lee,
As usual you hit a grand slam when it comes to making our jobs much easier...:D
