Hey guys!
Do y'all know of a way to get ACAD to prompt for selecting object rather than picking an internal point when pulling a hatch pattern from a palette?
Thanks,
Liz
Hatch: Boundaries: Add: Select objects
Is this what you want?
I'm sorry, I'm not entirely sure what to make of your response. Newbie here.
When using the hatch command typically, it gives you the option to select object. When using a hatch pulled from a custom palette, you're only prompted to pick a point. I would like to have the option to select object when using a hatch from a palette. Not sure if this is possible.
Thanks.
