eyeofnewt555 Posted May 26, 2016 Posted May 26, 2016 Hey guys! Do y'all know of a way to get ACAD to prompt for selecting object rather than picking an internal point when pulling a hatch pattern from a palette? Thanks, Liz Quote
delliott Posted May 26, 2016 Posted May 26, 2016 Hatch: Boundaries: Add: Select objects Is this what you want? Quote
eyeofnewt555 Posted May 27, 2016 Author Posted May 27, 2016 I'm sorry, I'm not entirely sure what to make of your response. Newbie here. When using the hatch command typically, it gives you the option to select object. When using a hatch pulled from a custom palette, you're only prompted to pick a point. I would like to have the option to select object when using a hatch from a palette. Not sure if this is possible. Thanks. Quote
