Hi,
Example: (image)
U usually use the FILLET command to connect 2 lines with an arc. If that not works i go to the next best thing; Tan Tan Radius (Circle > T)
But why does FILLET not always work the way i want?
When i click the lines before or after the tangent point or use the REVERSE command to reverse the direction of the lines, the result is always the same.
Any ideas? I am just wondering...
Edited by OMEGA-ThundeR
Maybe fillet won't do an arc larger than 180 degrees.
If the tool you want to use doesn't work at all the way you want it to and another one gets you close, use the one that gets you close.
If you think thats a problem try filleting two arcs there is that S bend again, its a buggy thing in autocad and you would think by now they would address it. This problem has existed form literally the first version of Autocad. Re arc fillet arc there are 4 solutions we have some other software and it recognises this problem and uses a different technique to solve the problem.
There are a number of lisps out there to help. Try this PS go clockwise and anti clockwise for two answers.
; draws an arc between 2 lines but does not erase
; by Alan H Aug 2015
(defun c:arcfill ( / pt1 pt2 pt3 pt4 obj1 obj2 obj3 obj4 obj5 obj6 pt5)
(alert "Pick in clockwise direction")
(setq oldsnap (getvar 'osmode))
(setvar 'Osmode 512)
(setq pt1 (getpoint "\npick 1st line"))
(setq obj1 (ssname (ssget pt1) 0))
(setq obj5 (vlax-ename->vla-object obj1)) ; convert to vl
(setq pt2 (getpoint "\npick 2nd line"))
(setq obj2 (ssname (ssget pt2) 0))
(setq obj6 (vlax-ename->vla-object obj2)) ; convert to vl
(setq rad (getdist "\nEter radius"))
(command "offset" rad Obj1 pt2 "")
(setq obj3 (vlax-ename->vla-object (entlast)))
(command "offset" rad Obj2 pt1 "")
(setq obj4 (vlax-ename->vla-object (entlast)))
(setq pt5 (vlax-invoke obj3 'intersectWith obj4 acExtendThisEntity)) ; centre pt
(setq pt3 (vlax-curve-getClosestPointto obj6 pt5))
(setq pt4 (vlax-curve-getClosestPointto obj5 pt5))
(command "arc" "C" pt5 pt3 pt4)
(vla-delete obj3)
(vla-delete obj4)
(setvar 'osmode oldsnap)
(c:arcfill)l
Try to measure the distance between your 2 lines(which do you wan to connect)then set your fillet radius to what distance you get divided into 2.
Just use Circle, TTR, trim and done. No need for lisp programs.
