Grrr Posted May 20, 2016 Posted May 20, 2016 Hi guys, Today I was working on one of my several ideas, which is aligning a selection set, by picking faces: 1.Select objects to align (SS) 2.Pick Source Face 3.Pick Destination Face (working in 3D) Needless to say that trying to get the dxf data from a 3D solid object - displays something nightmarish. So you can see the idea I've got: ; Pick 3D Object's face ; Attempt to align objects by picking faces: ; 1.Select objects to align (SS) ; 2.Pick Source Face ; 3.Pick Destination Face ; 4.The SS is aligned, where the Source Face and Destination Face share the same plane, and their centroids are matched ; *******************x <- mx ; * * ; * * ; * x <-cenx * ; * * ; * * ; mn-> x******************* ; ; Points mn, mx and cenx are collinear! ; Grrr ; Credits to: Lee Mac (defun C:test ( / SS msg continiue pt1 bpoly-ent1 bpoly-elist1 vla-bpoly1 mn1 mx1 box1 bpolys-cen1 pt2 bpoly-ent2 bpoly-elist2 vla-bpoly2 mn2 mx2 box2 bpolys-cen2) (if (and (princ "\nSelect objects to align, by picking faces") (setq SS (ssget "_:L")) (sssetfirst nil SS) ) (progn ; Will prompt for point, until the bpoly's elist is displayed: ; Picking Source Face: (setq continiue T) (while continiue (progn (setq pt1 (getpoint "\nPick the source face")) (command "_.UCS" "F" pt1 "") (command "_.BPOLY" pt1 "") (if (and (eq (cdr (assoc 0 (entget (entlast)))) "LWPOLYLINE") (not (member msg '("Function cancelled" "quit / exit abort" "Valid hatch boundary not found."))) ) (progn (setq bpoly-ent1 (entlast)) (setq bpoly-elist1 (entget bpoly-ent1)) (setq vla-bpoly1 (vlax-ename->vla-object bpoly-ent1)) (setq box1 (vla-getboundingbox vla-bpoly1 'mns 'mxs)) (setq bpolys-cen1 ( mapcar '(lambda (x1 x2) (/ (+ x1 x2) 2.0)) (setq mn1 (trans (vlax-safearray->list mns) 1 1)) (setq mx1 (trans (vlax-safearray->list mxs) 1 1)) ) ) (entmakex (list (cons 0 "POINT") (cons 10 bpolys-cen1) ) ) (entdel bpoly-ent1) (command "_.UCS" "W" ) (setq continiue F) ; how to set (entlast) to nil ? or not to be a (cons 0 LWPOLYLINE) ? So the code would reset ) (princ "\n*** Try again! ***") ) ) ) ; Picking Destination Face: (setq continiue T) (while continiue (progn (setq pt2 (getpoint "\nPick the destination face")) (command "_.UCS" "F" pt2 "") (command "_.BPOLY" pt2 "") (if (and (eq (cdr (assoc 0 (entget (entlast)))) "LWPOLYLINE") (not (member msg '("Function cancelled" "quit / exit abort" "Valid hatch boundary not found."))) ) (progn (setq bpoly-ent2 (entlast)) (setq bpoly-elist2 (entget bpoly-ent1)) (setq vla-bpoly1 (vlax-ename->vla-object bpoly-ent2)) (setq box2 (vla-getboundingbox vla-bpoly2 'mnz 'mxz)) (setq bpolys-cen2 ( mapcar '(lambda (x1 x2) (/ (+ x1 x2) 2.0)) (setq mn2 (trans (vlax-safearray->list mnz) 1 1)) (setq mx2 (trans (vlax-safearray->list mxz) 1 1)) ) ) (entmakex (list (cons 0 "POINT") (cons 10 bpolys-cen2) ) ) (entdel bpoly-ent2) (command "_.UCS" "W" ) (setq continiue F) ; how to set (entlast) to nil ? or not to be a (cons 0 LWPOLYLINE) ? So the code would reset ) (princ "\n*** Try again! ***") ) ) ) (command "_.3DALIGN" SS "" bpolys-cen1 mn1 mx1 ; the points must not be collinear! (in this example they are) bpolys-cen2 mn2 mx2 ; the points must not be collinear! (in this example they are) ) );progn );if (princ) );defun My goal is to represent the aligning close to the Autodesk Inventor's, see this sample video from 1:37, where the pink part is aligned to the brown one. (Atleast something close to this). At the moment I'm having problems, to find a "third" non-colinear point for alignment. In the following picture you can see the temporary bpoly in yellow, and the points I currently have in red: Feel free to modify the code if you have better suggestions. For me writing such codes is a hobby and I'm not a real programmer, so I don't need any credits. (and yes - I thought why not using the bpoly's vertices - but it would took me few days to figure it out) Quote
