sandiegophil Posted May 20, 2016 Posted May 20, 2016 Hello all, I would like to know if anyone has been able to do the following: - create a corridor leaving all 'CreateCorridor' - 'Assembly Insertion Defaults' to the default values in the settings tab. -apply a different "style" that changes all the increment values. I'm trying to find a way to make custom corridor styles so users do not have to go in and manually change all the 25' increments to 50' (for example). They want to apply a 25' style and then change that to a 50' style at will. Any and all help is appreciated. thanks, phil Quote
