is there a way to quick select polylines by elevation???
i have this elevations something like 1, 1.3, 1.5, and 1.6, 2, 2.5
so i want to select from 1 to 1.5 and put it on a layer, and from 1.6 to 2.5 put on different layer....
is it possible to quick select by elevation
From a side view you could do this.
not very lispy but practical..
Another non lisp approach would be using the FILTER command.
The way I set this up, the FILTER is actually searching for all Polylines with Elevations in the RANGE from 1 to 1.5, but that can be easily altered.
Once you set up such a Filter, you can save it as a preset, so the next time you need it, all you need to do is to select it from the dropdown Named filter menu.
QuickSelect will not allow you to do a range like this, or multiple elevations in one search. :|
Edited by Dadgad
(defun spelv (lo hi)
  (ssget (list '(0 . "LWPOLYLINE") '(-4 . ">=") (cons 38 lo) '(-4 . "<") (cons 38 hi)))
Suggest you take a look at Lee Mac's page on ssget filters
http://www.lee-mac.com/ssget.html
Once you got the selection set, It's only a matter of using entmod to change the layer
of every entity in it.
i didnt get the code :(
A bit more
(defun c:spelv ( / lo hi)
  (setq ss (ssget (list '(0 . "LWPOLYLINE") '(-4 . ">=") (cons 38 (getreal "enter low value")) '(-4 . "<") (cons 38 (getreal "Enter high value")))))
  (command "-chprop" ss "" "La" (getstring "Enter Layer name") "")
