malkasun Posted May 14, 2016 Posted May 14, 2016 I try to install autocad 2017. can't install it. coming error. see attached screenshots pls help me Quote
ReMark Posted May 14, 2016 Posted May 14, 2016 If you are using Trend Micro anti-virus software you must disable it before running the setup.exe program. Quote
malkasun Posted May 15, 2016 Author Posted May 15, 2016 i am not use the trend micro anti virus. i am using the avast. i tried, it disabled. coming same error. Quote
SLW210 Posted May 16, 2016 Posted May 16, 2016 See if this helps....Preparing your System for Installation Quote
