cat3appr Posted May 3, 2016 Posted May 3, 2016 hello, I'm having some issues with picking up folders located in another PC within the network... for example CAD is not memorizing the path and each time i need to dig over plenty of folders. for example I'm using an autocad tool to automatize sine drawing constructions, and for this tool in particular i'd like to save some preset paths within the network that i always use. Could you help me with this? thanks! Quote
BIGAL Posted May 3, 2016 Posted May 3, 2016 You can do exactly that MAP A NETWORK DRIVE normally in the range A:-Z: we have K: P: S: if this helps. This can be a directory at levels below root. Quote
