I note that you're also supply a point to the selection prompt - this shouldn't be necessary and may be affecting the selection (as it will select what is found at that point on screen depending on the current view).
  • Replies 21
  • Grrr
    7
  • Lee Mac
    6
  • Tharwat
    4
  • ibach
    4
How else do you propose to do a selection?
(setq blockdata (nentsel "\nSelect block:"))
I mean, this is the only user input here and only the dust at my screen it could encounter but the block...
I shall test that though, selecting the blocks one by one programmatically...
I am out of ideas and is the only thing I did not try, I think.
Should not happen though, situation is fairly clear of other stuff and angle calculus goes well too.
