Best Practices - c3d 2016
Hello,
I have found the 'best practices' under help / learning resources but want to get a pdf of this. Back in the old days we received books, now we get html. Does anyone have a resource for these?
Thanks,
phil
I'm not sure I quite understand what it is you're trying to achieve and what documents are you speaking of? I looked up learning resources in the help and saw a bunch of stuff and not sure what one in particular you are speaking of.
Thanks,
Miller
You can try using a Print to PDF utility. The one I'm familiar with is Win2PDF, but there are others out there as well. Just print the help files and select the driver as your printer.
Miller,
From the help pull-down, under 'learning resources' 12th item from the bottom there is a topic called 'Best Practices Guide'. I am trying to find a pdf file that is all inclusive of that topic. Autodesk used to provide actual, physical books for these items but no longer does.
Thanks,
phil
You cleared that up perfectly Phil. Let me take a look and I'll get back to you sir.
Miller
benhubel,
I have tried online utilities, acrobat x pro and acrobat pro dc. All of them will only produce the first sheet, the introduction. I have tried to do the entire site, 1 level deep, 100 level(s) deep all with no success. Any additional suggestions would be appreciated.
Thanks,
phil
benhubel,
thank you for the file and the effort. it is appreciated.
Glad to help. It seems that there are yet a few things on this forum that I can be of assistance with :)
Being that I'm relatively new to the CAD side of things, I have to jump on the few that I actually know something about.
The move away from pdfs to html help files annoys me also as the search capabilities usually aren't as good.
all help is always appreciated!:D
Organic,
I couldn't agree more. At least provide the option to replicate sections of the html to pdf.
