xref can't be detached
Is the xref loaded more than once? Xref's that are loaded multiple times cannot be detached until the duplicates have been deleted.
Also, if an xref is nested inside another xref, it cannot be detached.
Anytime I've had an issue where I can't unload an x-ref I've been able to purge the drawing and then unload the xref. I don't know why it works, and you probably want to save a copy for safe keeping before doing it, but it's worth a shot.
Switch to tree view to check that it's not being referenced in one of the other xrefs - that would prevent it being detached.
Find what layer it's on - if that's locked or frozen I *think* that stops xrefs being detachable.
dJE
