battman Posted April 21, 2016 Share Posted April 21, 2016 Hi All, i'm trying to make a new linetype with text, but i want the text to have a field that displays the length of the line. Does anyone know how to do this? Or if it's possible? Any help would be much appreciated! Quote Link to comment Share on other sites More sharing options...
battman Posted April 21, 2016 Author Share Posted April 21, 2016 thanks ReMark, the reason I would want it to be a linetype though would be so that I can have multiple segments, like as a polyline, and it can display the total length of the polyline. I'm thinking something like the GAS linetype or the HOT WATER supply linetype, but where the text is a field. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 21, 2016 Share Posted April 21, 2016 Can't say I've seen anything like that and any workaround I have tried has been too clunky. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 22, 2016 Share Posted April 22, 2016 On a single line it can be done using a dimension, but thats not applicable for a pline. Like Remark what about just pick and update objects or search by layer etc. Quote Link to comment Share on other sites More sharing options...
steven-g Posted April 22, 2016 Share Posted April 22, 2016 Someone might know a way with LISP, you could use the measure command and insert a block with a field along a line/pline, you could of course add other text or a wipeout or background hatch field.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 23, 2016 Share Posted April 23, 2016 (edited) This is based on Steven-g dwg it will label but if you change the pline the blocks do not change, one way around this is to erase all the blocks move the pline then redo the (c:plen), this involves other routines but the method is quite simple using ssget "F" done below Simplest is the need to be able to put the field in a .LIN A,5.08,-5.08,5.08,-5.08,["G",STANDARD,S=1.8,R=0.0,X=-1.8,Y=-.9],-3 need the "G" to be a field. (defun c:plen ( / obj) (setq obj (entsel "Pick line or pline")) ; probably want a layer set here (command "measure" obj "B" "len" "Y" (getdist "enter spacing")) ) ; pline co-ords example ; By Alan H (defun getcoords (ent) (vlax-safearray->list (vlax-variant-value (vlax-get-property (vlax-ename->vla-object ent) "Coordinates" ) ) ) ) (defun co-ords2xy () ; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z (setq len (length co-ords)) (setq numb (/ len 2)) ; even and odd check required (setq I 0) (repeat numb (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) )) ; odd (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords)(nth (+ I 2) co-ords) )) (setq co-ordsxy (cons xy co-ordsxy)) (setq I (+ I 2)) ) ) ; erase blocks (defun c:eraseblk ( / ss) (setq co-ords (getcoords (car (entsel "\nplease pick pline")))) (co-ords2xy) ; list of 2d points making pline (setq ss (ssget "f" co-ordsxy (list (cons 0 "Insert")))) (command "erase" ss "") ) Edited April 23, 2016 by BIGAL Quote Link to comment Share on other sites More sharing options...
battman Posted April 25, 2016 Author Share Posted April 25, 2016 Thanks everyone, BIGAL, I used the first code you wrote above and saved it as a .lsp, loaded it with appload, and used the command "plen" on steven-g's drawing. It placed a measurement along my pline in regular intervals, which is great! but the measurement was always 15.81 m... which was the length of steven-g's line that he drew. When I draw a new line, it doesn't know to measure that one. Maybe the answer is in the second code you provided... but my novice autocad brain doesn't understand what to do with it. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 25, 2016 Share Posted April 25, 2016 I tested the small plen again at 2000 as spacing on a new pline and works fine, you may need to play with the dynamic block in terms of scale etc for small distance. Used Bedit to edit block maintain insertion point. Quote Link to comment Share on other sites More sharing options...
