Civardi Posted April 13, 2016 Posted April 13, 2016 Hey all, wondering is there a way to paste special using autocad entities paste link command? I want to see any images come through that are in my excel file i am pasting from. I do know i can you use the paste exel link and have images come throu. PLEASE THIS IS NOT WHAT I AM AFTER. I am after paste special link autocad entities only to show images. Thanks Quote
RobDraw Posted April 13, 2016 Posted April 13, 2016 Are you wanting to extract images from an Excel file and paste them into AutoCAD? Quote
Civardi Posted April 13, 2016 Author Posted April 13, 2016 kind of. I want to paste from excel using the paste special command>paste link>autocad entities. Quote
RobDraw Posted April 14, 2016 Posted April 14, 2016 Doesn't seem to work here. It might help if you could post the file you are trying to copy. Quote
SLW210 Posted April 14, 2016 Posted April 14, 2016 I do not believe that will work, supposedly it will work with Windows Metafiles, but I never got that to work well either. Why exactly do you need them as AutoCAD Entities, maybe there is a different method to achieve your results. Quote
Civardi Posted April 14, 2016 Author Posted April 14, 2016 When i paste special/paste link as microsoft excel worksheet the plot quality is terrible. The line weights suck and the bitmap image is no good when i plot. Using autocad entities option the lineweights are good when i plot. I also have more control over aligning my columns. the data i am copy from excel is a couple of columns with an image in one of the columns. (Sample attached looks fine. The issue is when i plot even though my plot quality is set to highest.) Quote
BIGAL Posted April 15, 2016 Posted April 15, 2016 Have you looked at the default "insert image" but you will need a BMP JPG etc. Quote
