VBA SelectionSet not working on VB.NET
habakay
Hi,
I'm new at .NET for Autocad. I try to convert my VBA codes to .NET. But I have some troubles. I can use the codes below without any errors at VBA but it gives an error on .NET
VBA Codes:
Dim oSset As AcadSelectionSet
Dim FilterType(3) As Integer
Dim FilterData(3) As Variant
FilterType(0) = -4
FilterData(0) = "<OR"
FilterType(1) = 0
FilterData(1) = "LINE"
FilterType(2) = 0
FilterData(2) = "LWPOLYLINE"
FilterType(3) = -4
FilterData(3) = "OR>"
oSset.SelectOnScreen FilterType, FilterData
I try to convert them like this;
Dim oSset As Autodesk.AutoCAD.Interop.AcadSelectionSet
Dim FilterType(3) As Object
Dim FilterData(3) As Object
FilterType(0) = -4
FilterType(1) = 0
FilterType(2) = 0
FilterType(3) = 4
[color=red]oSset.SelectOnScreen([/color][color=red]FilterType, [/color][color=red]FilterData)[/color]
and it gives an error on "selectonscreen" line. The error is "Invalid argument FilterType in SelectOnScreen"
I also try "Short " and "Integer" variable types for "FilterType" but nothing change.
I would appreciate if you can help.
The value in your line of code:
FilterType(3) = 4
should be "-4"
