koko Posted April 5, 2016 Posted April 5, 2016 Hello, 1) How can I convert a file to be applicable to be edited in inventor from auto cad? 2) I have an STL file which I have tried to use the mesh add on from inventor to convert it to an editable file with no luck. Anybody know how to convert an STL file to an editable file in inventor? thanks in advance for your help Quote
Lazer Posted April 6, 2016 Posted April 6, 2016 Hi, 1. Open Inventor, new sketch- insert autocad file (on the ribbon) 2. Once had to do this and downloaded a plugin from the net but was far from robust. It may well be on the autodesk apps site? Quote
JD Mather Posted April 6, 2016 Posted April 6, 2016 Hello, 1) ... from auto cad? (AutoCAD?) 2) I have an STL file... thanks in advance for your help 1. Attach your *.dwg file here and end all doubt. 2. Zip and attach your *.stl file here and end all doubt. Quote
