Deby Ferdian Posted April 4, 2016 Share Posted April 4, 2016 (edited) I have several times looking for the shortcut key of "VPORT cycle" and the search results are a lot of people say with CTRL+R but it did not work for me what happened? is there anyone who can explain this .. Edited April 4, 2016 by Deby Ferdian I have correction this! there are wrong words.. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 4, 2016 Share Posted April 4, 2016 Do you have one active when you start? Quote Link to comment Share on other sites More sharing options...
Deby Ferdian Posted April 4, 2016 Author Share Posted April 4, 2016 Yes. and I also try with "mspace" and "pspace" to troubleshoot this.! Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 4, 2016 Share Posted April 4, 2016 Are you holding "Ctrl" and tapping "R"? Quote Link to comment Share on other sites More sharing options...
Deby Ferdian Posted April 4, 2016 Author Share Posted April 4, 2016 Yes. I am.. But that has been my suspicion is about my worry will delete the file shortcut key in the CUI that is because once ever when I make changes to one of the function keys to other control, but now I didn't wear anymore at this time and I do not know where the original function to??? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 4, 2016 Share Posted April 4, 2016 Okay, I understand now but I do not know how to reset it. Someone else should know how to help you. Quote Link to comment Share on other sites More sharing options...
Deby Ferdian Posted April 4, 2016 Author Share Posted April 4, 2016 Ok. it's okey RobDraw thanks for your time anyway.. Quote Link to comment Share on other sites More sharing options...
Deby Ferdian Posted April 4, 2016 Author Share Posted April 4, 2016 Yes.. Finally I found it and fix the problem by myself! It's simple enough, just search in the CUI at "All command and Control" category then type in dialog search box as "CTRL+R" then you only have to drag it into "Keyboard shortcut" key and for the last assign way the key like you want it.. I found this at source of http://forums.autodesk.com/t5/autocad-2007-2008-2009/switching-between-viewports-ctrl-r-not-working/td-p/2004250 Quote Link to comment Share on other sites More sharing options...
