nicolas Posted April 1, 2016 Posted April 1, 2016 Hi, I have a few dwg shop drawings with some 80+ layout in them. I need to plot some of them but I have access to only the tabs that are shown on the screen. Is there a way to plot say the 40th sheet/tab back to the 1st tab using for example shift+home after selecting the 40th tab. I think it used to be that way in the past. I am using Autocad 2015. Thanks. Quote
BIGAL Posted April 1, 2016 Posted April 1, 2016 A couple of things I have done 1st yeah use publisher, But I have plot range tabs.lsp 40-52 to a set printer two questions much easier than publish. 2nd is a GOTO which I wrote for just this problem goto 36 will go to that tab number if it matches your sheet number then easy. Bothe are here http://www.cadtutor.net/forum/showthread.php?84430-Move-layout-Rename-layouts-Goto-layout Quote
