Hi all,
I was wondering if there is any way that I could set all of my mleaders to have a same angle for their 1st segment. I have set that in my mleader style and applied the style to my mleader objects but that didn't force them to be in parallel.
In brief, this is what I have:
This is what I want:
Works fine here, I believe you need to also check the Maximum Leader Points box for it to work.
Can you iterate the steps you follow to get it done? It doesn't work on my end :(
Style setting applies on the new mleaders that I create but on want to modify the 'existing' mleaders which have been pasted from other drawing.
Editing the style won't change existing ones, not the angle anyway. Is that what you were after, changing the angle after the fact?
I knew that already. That's why I was asking about how to set the angle property afterwards.
There is a MLEADERALIGN command that will align the text after placement, but doesn't change the leader angle.
Might be a bug, do you have all service packs and hotfixes installed?
I wouldn't call it a bug. Rather a limitation. I've looked up for dxf code of it. Looks like it's a deadened street.
Anyone could possibly help me with this please?
