NEWMAN1006 Posted March 31, 2016 Posted March 31, 2016 Hello, I am tasked with calculating a volume of an area to calculate how many gallons it will hold. I then need to compare this tin surface at a specific elevation so basically i have a bowl and need to put a lid on it to see how much volume there is at the containment fail elevation. was looking for other ideas as to how to do this right now i'm making a plane at the set elevation and then making on additional plane to move up and down till I get the containment I need Thanks Quote
NEWMAN1006 Posted March 31, 2016 Author Posted March 31, 2016 PDF Example of what I'm trying to do CA-8 TK-64 .pdf Quote
TheCADnoob Posted March 31, 2016 Posted March 31, 2016 Id be tempted to throw a trapezoid at it (V=LH(A + B)/2) and do a rough calculation... but thats why im not making the real money haha. If nothing else it can give you an idea where to start looking to put your lid. Quote
Mefloump Posted March 31, 2016 Posted March 31, 2016 Couldn't you make the empty space a 3D object and then run the MASSPROP command? Quote
NEWMAN1006 Posted March 31, 2016 Author Posted March 31, 2016 I have no idea how that command works Quote
Mefloump Posted March 31, 2016 Posted March 31, 2016 https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-CAA51229-293E-4A0C-BFF3-93226252CF13-htm.html Quote
rkmcswain Posted March 31, 2016 Posted March 31, 2016 Are you doing this with plain AutoCAD? You're in the AutoCAD forum, but your "Computer Details" says "Civil 3D 2012" Quote
NEWMAN1006 Posted March 31, 2016 Author Posted March 31, 2016 No I'm using Civil 3d 2014 should I have put it in a different thread? Quote
SLW210 Posted March 31, 2016 Posted March 31, 2016 I moved your thread to the Civil 3D & LDD Forum for you. Quote
BIGAL Posted April 1, 2016 Posted April 1, 2016 Make a new surface larger than your bowl with say 5 points but each point has the same elevation then just use the ciV3d volume calc compare two surfaces. Quote
NEWMAN1006 Posted April 1, 2016 Author Posted April 1, 2016 Thanks for the input I will give these a try Quote
MillerMG Posted April 6, 2016 Posted April 6, 2016 I just had to do this by hand in my Hydrology and Drainage course...Wasn't too bad. Having CAD sure helped a lot Quote
