tnolan3 Posted March 27, 2016 Share Posted March 27, 2016 Using Civil 3D 2016 and having Intermittent Problems with not being able to remove items from the selection set. Anyone else having this problem? Terry Nolan www.FloridaDraftingServices.com www.1stProto.com 1stProto Design Services Quote Link to comment Share on other sites More sharing options...
tombu Posted March 28, 2016 Share Posted March 28, 2016 Can you be more specific as to commands or procedures you use that lead to this? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted March 28, 2016 Share Posted March 28, 2016 If you are referring to shift deselect, I've run into this when using Raster Design. I had to either re-enable it or use "R" to remove. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted March 28, 2016 Share Posted March 28, 2016 Using Civil 3D 2016 and having Intermittent Problems with not being able to remove items from the selection set. It could be this. Quote Link to comment Share on other sites More sharing options...
