HI Everyone i am trying to Build this Sword in AuTocad its very simple but some how i can't make a sharp corner for the blade if anyone has Suggestion about it. ?
I'm guessing that sword has a hollow ground blade. Is that correct?
What have you produced so far? Can you attach a copy of the drawing to your next post?
Edited by ReMark
My halfhearted attempt at creating a hollow ground blade. Note that it is comprised of three sections. The long straight section is a solid while the other two sections are surfaces. Visual style = Conceptual.
Maybe I should not have tried this until I had my usual ten cups of coffee as my brain is still in a sleep fog.:?
For what it is worth...
If I had to fully explain what I did I don't think I could. Someone smarter than me will figure it out though and post a real solution. It was interesting to say the least. Thanks for the challenge.
Getting better?:unsure:
Constructed this using five surfaces (really...despite the way it looks) and it went pretty quickly this time.
Not step will be to construct as a solid. Consider it a work-in-progress.:lol:
I wish you could explain how you did it. i would love to know how to draw this.
After my tenth cup of coffee. I'm on number eight right now.:lol:
Ten four. I'm on my third Mountain Dew :D
Haven't tried it yet but I wonder if the sword blade could be created using a couple of solids, of the appropriate shapes, and the INTERFERE command? Just thinking.:unsure:
Blade as a 3D model. Not quite there yet though as I have a slight anomaly (both sides) where the blue arrow is pointing.
The easy answer still alludes me. Curses! Foiled again.:x
Edited by ReMark
Tip of the day. Sword tip that is...as a solid.
Call me...BladeRunner.:shock:
What are those little "artifacts" on the blade edge?
Pieces of skin, muscle and fat cut from the soft underbelly of my foes.:twisted:
Edited by ReMark
It was easier than I thought after all. The image below is a 3D solid through and through (tip to tail). I took a half profile of the blade in plan view and extruded a half profile of the blade in section along it. I then sliced the result mirrored the remainder and finally unioned the two halves together. Visual style = Realistic.
I admit my blade is easier because it is straight for the most part unlike the OP's. Perhaps if I get a chance I'll tackle the blade shape shown in his posted image. Or perhaps not. All depends on how much coffee I drink.
It seems that you have figured it out 8)
It looks really good! You and that coffee hahaha :lol:
Would it be possible for you to post the .dwg? I would very much be interested in playing around with it. Let me know ReMark. Thank you
Miller
BAAAAHAHAHAHAHAHAHAHAHa! Puny demi-gods.....(Hulk voice)
I'd attach the drawing but then you'd have to deal with all my false starts and mistakes.:ouch::lol: I usually leave these kinds of things in a drawing like this so I can remind myself later what not do you when I pick up the drawing and start working on it again. A day or two after it appears the OP got what he/she wanted I usually just delete the drawing.
PM me with your email address and I'll send you a copy. You've been warned though.:lol:
Lol! Roger that sir. I will make sure that I keep that in mind and no judgement will be passed, not that you would care even if I had. haha
My thought process tends to be scrambled when I do these sort of one-offs while attempting to assist someone. My mind is going in several directions at once so I will try something, change my mind, leave it and try something else all in the same drawing.
OK...email has been sent. Beware the chaos.
