lucascantelle Posted March 18, 2016 Posted March 18, 2016 (edited) Hello folks! I would like to know if you guys could help me to align multiple lines to an specific point. Take a look at this image. I want to align all color lines to the white one at the bottom. I tried to move them, but I need a reference point and I do not know how to do it. Ive been searching about it here, but also unsuccessful. Edited March 19, 2016 by lucascantelle IMG LINK FIXED Quote
ReMark Posted March 18, 2016 Posted March 18, 2016 (edited) Image missing? OK...since I see no evidence of an image I'll take a wild guess here and say try using the ALIGN command. Your Help file will give you the particulars on how it is used. Edited March 18, 2016 by ReMark Quote
Dadgad Posted March 19, 2016 Posted March 19, 2016 (edited) Welcome to CADTutor Lucas. Check out this Lyn Allen link, regarding the use of the CHANGE command. http://lynn.blogs.com/lynn_allens_blog/2015/11/a-thanksgiving-tip-on-cleaning-up-your-lines-with-the-top-secret-change-command.html The part dealing with your question is near the end of the clip. Edited March 19, 2016 by Dadgad Quote
lucascantelle Posted March 19, 2016 Author Posted March 19, 2016 Thank you Dadgad for wlecoming me. I tried to use CHANGE but its not working as I neeed. I need to put all lines together on the same plane, same elevation in that case, but do it at once! I fixed the missing image file on my first post. Thank you and hope it can help you to help me! Quote
eldon Posted March 19, 2016 Posted March 19, 2016 Perhaps the picture does not show a plan view?? Perhaps Flatten command would help. It would be easier to help you if you could post the drawing file. Quote
Dadgad Posted March 20, 2016 Posted March 20, 2016 (edited) Thank you Dadgad for wlecoming me. I tried to use CHANGE but its not working as I neeed. I need to put all lines together on the same plane, same elevation in that case, but do it at once! I fixed the missing image file on my first post. Thank you and hope it can help you to help me! If you use the ELEVATION option in the CHANGE command you can do that too, just determine the elevation of that one line first, then specify that as the new elevation value, after selecting all of the lines (follow the commandline prompts). Another way to do this would be using Properties or QUICK PROPERTIES, by selecting all of the lines or plines, and setting the Z Start values and Z End values to whatever the desired Z value is. Edited March 21, 2016 by Dadgad Quote
