I think it could. It might get tricky on which part of layer name you would remove.
I need to remove / replace the last 4 charaters
Hi,
If you want to remove the last 4 characters , just replace number 5 to 4 in the my codes for the OP in this thread HERE
But if you want to replace , just use the function strcat to add any string you wish as prefix or suffix. easy right?
NOTE: but if you are after renaming layer names with these codes , you need to check first if the new layer name is not already existed.
Good luck.
  • 3 years later...
Hi all,
Just an amendments requested.
how about, if we want to remove the characters from left; or having an option from left or right side.
like I want to keep only the x characters from the right and remove all or remove the x charaters from the right.
Thanks
Edited by CADWORKER
Perhaps:
(setq str "ABCDEFOO")
(setq str (vl-string-left-trim "ABC" str))
(vl-string-right-trim "FOO" str)
Careful with the vl-string-*-trim functions @ronjonp 😉:
_$ (vl-string-left-trim "ABC" "ABCCBA")
I would always suggest substr for such purposes, e.g.:
_$ (setq s "ABCDEF")
"ABCDEF"
_$ (substr s 4) ;; Remove 3 chars from left
"DEF"
_$ (substr s 1 (- (strlen s) 3)) ;; Remove 3 chars from right
"ABC"
Edited by Lee Mac
DOH!
just 4fun a quickie before breakfast 🍞 🍳 ☕, don't see to much practical use for this 😄
; letter cutter
(defun c:le_cut ( / cut-size front-cut)
  (if (null (setq cut-size (getenv "cut-size")))(setenv "cut-size" (setq cut-size "1")))
  (if (null (setq front-cut (getenv "front-cut")))(setenv "front-cut" (setq front-cut "1")))
  (cut_dialog)
(defun cut_dialog ( / f p d r)
  (and (setq p (open (setq f (vl-filename-mktemp ".dcl")) "w"))
       (write-line "le_cut:dialog {label=\"Letter Cutter\";:concatenation {children_fixed_width=true;" p)
       (write-line ":text_part {key=\"tp1\";width=3;}:button {key=\"upper_cut\";label=\"+\";width=1;}" p)
       (write-line ":button {key=\"lower_cut\";label=\"-\";width=1;}" p)
       (write-line ":button {key=\"front_cut\";label=\"<>\";width=1;}" p)
       (write-line ":text_part {key=\"tp2\";width=5;}} spacer;ok_cancel;}" p)
       (not (setq p (close p)))(< 0 (setq d (load_dialog f)))(new_dialog "le_cut" d)
         (set_tile "tp2" (if (= front-cut "1") "Front" "Back"))(set_tile "tp1" cut-size)
         (action_tile "front_cut" "(toggle_cut)")(action_tile "upper_cut" "(upper_cut 1)")
         (action_tile "lower_cut" "(upper_cut -1)")(action_tile "accept" "(setq r (get_tile \"lb\"))(done_dialog 1)")
         (action_tile "cancel" "(setq r nil)(done_dialog 0)")
         (start_dialog)(unload_dialog d)(vl-file-delete f))) (cond ((= r "") nil)(t (find_cut))))
(defun toggle_cut ()
  (set_tile "tp2" (if (= (setenv "front-cut" (if (= front-cut "1")(setq front-cut "0")(setq front-cut "1"))) "1") "Front" "Back"))
(defun upper_cut (i)
  (set_tile "tp1" (setenv "cut-size" (if (= "0" (setq cut-size (itoa (+ (atoi cut-size) i))))(setq cut-size "1") cut-size)))
; scan for string %p1=cornerpoint1 , %p2=cornerpoint2 , %fl=flag , if T include block text)
(defun sfs (%p1 %p2 %fl / _gip _pin _gbs ss i l e y )
  ; get insertionpoint e=ename
  (defun _gip (e) (if (assoc 11 (setq e (entget e)))(cdr (assoc 11 e))(cdr (assoc 10 e))))
  ; point inside a=point , b=cornerpoint1 , c=cornerpoint2
  (defun _pin (a b c) (if (and (>= (car a)(min (car b)(car c)))(<= (car a)(max (car b)(car c)))
    (>= (cadr a) (min (cadr b)(cadr c)))(<= (cadr a) (max (cadr b)(cadr c)))) t nil))
  ; get block string a = block (ename) , f=include (m)text , c=etype , r=result
  (defun _gbs (a f / c d r)
    (while (and (setq a (entnext a))(setq c (cdr (assoc 0 (entget a)))))
      (cond ((not (member c '("ATTRIB" "TEXT" "MTEXT")))) ((not (_pin (_gip a) %p1 %p2)))
     (t (if (= c "ATTRIB")(setq r (cons a r)) (if (and f (member c '("TEXT" "MTEXT")))(setq r (cons a r))))))) r)
  ; main routine
  (if (setq ss (ssget "c" %p1 %p2))
    (repeat (setq i (sslength ss)) (setq y (cdr (assoc 0 (entget (setq e (ssname ss (setq i (1- i))))))))
      (cond ((member y '("TEXT" "MTEXT" "ATTDEF"))(setq l (cons e l)))
     ((eq y "INSERT")(setq l (append l (_gbs e %fl)))))))
  l
; use (sfs p1 p2 T) for including block texts
(defun find_cut ( / p1 p2)
  (princ "\nSelect texts or attributes to cut")
  (while (and (setq p1 (getpoint "\nSelect first corner :"))(setq p2 (getcorner p1 "\nSelect second corner :")))
    (mapcar 'cut_me (mapcar 'vlax-ename->vla-object (sfs p1 p2 nil)))
    (vla-Regen (vla-get-activedocument (vlax-get-acad-object)) acActiveViewport)
  (prin1)
(defun cut_me (o / s)
  (if (and (vlax-property-available-p o 'textstring)(> (strlen (setq s (vla-get-textstring o)))(atoi cut-size)))
    (vla-put-textstring o
      (if (= front-cut "1") (substr s (1+ (atoi cut-size))) (substr s 1 (- (strlen s) (atoi cut-size)))))
(vl-load-com)
; (c:le_cut)
Edited by rlx
THANKS LeeMac, Ronjonp and RLX
for your suggestions;
Busy for the day so let me try and amend the code and get back to you.
Thanks again.
