I was looking at the "VBA and Excel" program on the AfraLisp website and I am trying to code my own application which is based on it. I had a question on this portion of code
[color="red"]Private Sub UserForm_Initialize()
Dim BlkG(0) As Integer
 Dim TheBlock(0) As Variant
 Dim Pt1(0 To 2) As Double
 Dim Pt2(0 To 2) As Double
 'declare local variables
 Set acad = GetObject(, "AutoCAD.Application")
 'set reference to AutoCAD
 Set doc = acad.ActiveDocument
 'set reference to the drawing
 Set ms = doc.ModelSpace
 'set reference to model space
 Set ssnew = doc.SelectionSets.Add("TBLK")
 'create a selection set
 Pt1(0) = 0: Pt1(1) = 0: Pt1(2) = 0
 Pt2(0) = 3: Pt2(1) = 3: Pt2(2) = 0
 'set up the array
 BlkG(0) = 2
 'group code 2 for block name
 TheBlock(0) = "MATLIST"
 'the name of the attribute block
 ssnew.Select 5, Pt1, Pt2, BlkG, TheBlock
 'get the block [/color]
What is the array for? (Pt1(0), Pt1(0) .. etc)
Edited by tmccar
Firstly you need to read up on how to properly post code on the forum and not simply use copy and paste.
There are two arrays Pt1() and Pt2() and each array has 3 elements which are the X,Y,Z coordinates of two points.
Edited by Tyke
Please read the Code Posting Guidelines and edit your post to include the Code in Code Tags
[NOPARSE]
CODE GOES HERE
[/NOPARSE].
Ok, I hope it looks ok now.
I was wondering what were the points used for?
The points are for a window selection 0,0,0 3,3,0
This little bit may help note you can get at block attributes by the order of creation you do not need tag name.
Set SS = ThisDrawing.SelectionSets.Add("pit1sel")
SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal
For Cntr = 0 To SS.Count - 1
If SS.Item(Cntr).Name = BLOCK_NAME Then
  attribs = SS.Item(Cntr).GetAttributes
  If attribs(0).TextString = pitname Then
Ok, I get it! Thanks BIGAL
