CADIDAC Posted March 19, 2007 Posted March 19, 2007 are there any lisps for converting ellipses to polylines. I am tired of not being able to make regions that include ellipses or being able to add them to preexisting polylines. Quote
dbroada Posted March 19, 2007 Posted March 19, 2007 I'm not sure about a LISP but you can draw them as PLINES in the first place.... PELLIPSE System Variable Type: IntegerSaved in: DrawingInitial value: 0 Controls the ellipse type created with ELLIPSE. 0 Creates a true ellipse object. 1 Creates a polyline representation of an ellipse 1 Quote
CADIDAC Posted March 19, 2007 Author Posted March 19, 2007 I was hoping that I wouldn't have to do that, being that I will have to redraw significant amount of my drawing. But if thats the only way. Are there any commands to convert ellipse to plines? Quote
fuccaro Posted March 19, 2007 Posted March 19, 2007 Maybe this could help you: http://www.cadtutor.net/forum/showthread.php?t=1639 Quote
VVA Posted March 20, 2007 Posted March 20, 2007 My variant (defun C:E2P (/ adoc el ssnab en item lays lay lock pell ptcen osm) (setq adoc (vla-get-activedocument (vlax-get-acad-object))) (setq lays (vla-get-layers adoc)) (vla-startundomark adoc) (setq ssnab (ssget '((0 . "ELLIPSE")))) ;_Выбор Region'ов в рисунке (setq pell (getvar "PELLIPSE")) (setq osm (getvar "OSMODE")) (setvar "PELLIPSE" 1) (while (and ssnab (> (sslength ssnab) 0) ) (setq el (ssname ssnab 0)) (setq en (vlax-ename->vla-object el)) (setq lay (vla-item lays (vla-get-layer en))) (if (= (vla-get-lock lay) :vlax-true) (progn (vla-put-lock lay :vlax-false) (setq lock (cons lay lock)) )) (setq item (vla-get-ObjectName en)) (cond ((= item "AcDbEllipse") (setq ptcen (vlax-safearray->list (vlax-variant-value (vla-get-center en)) ) ) (command "_ellipse" "_C" ptcen (mapcar '+ ptcen (vlax-safearray->list (vlax-variant-value (vla-get-MajorAxis en)) )) (mapcar '+ ptcen (vlax-safearray->list (vlax-variant-value (vla-get-MinorAxis en)) ))) (mapcar '(lambda (x y) (vlax-put-property (vlax-ename->vla-object (entlast)) x y) ) '(Linetype LineWeight Color Layer) (mapcar '(lambda (x) (vlax-get-property en x) ) '(Linetype LineWeight Color Layer) ) ) (vla-Delete en) ) (t nil) ) (ssdel el ssnab) ) (setvar "PELLIPSE" pell) (setvar "OSMODE" osm) (if lock (foreach x lock (vla-put-lock x :vlax-true)) ) (vla-endundomark adoc) (if (= (getvar "DWGCODEPAGE") "ANSI_1251") (princ "\nПреобразование Ellipse завершено") (princ "\nTransformation Ellipse is completed") ) (princ) ) (if (= (getvar "DWGCODEPAGE") "ANSI_1251") (princ "\nНаберите в ком. строке E2P") (princ "\nType E2P to run command")) Transformation of splines, circles, lines, ellipses, 2d and 3d polylines in 2d polylines (linear segments) ConvTo2d -transformation of linear objects in 2D polylines ConvTo3d -transformation of linear objects in 3D polylines Quote
CADIDAC Posted March 20, 2007 Author Posted March 20, 2007 when copying the text and saving in notepad will format, unicode, unicode big endian, or UTF-8, make a difference? I ask because I am saving and successfully loading them but when typing the defun c:e2p value, in the last case e2p, autocad displays an error. Quote
VVA Posted March 20, 2007 Posted March 20, 2007 Without Russian Text (defun C:E2P (/ adoc el ssnab en item lays lay lock pell ptcen osm count) (setq adoc (vla-get-activedocument (vlax-get-acad-object))) (setq lays (vla-get-layers adoc) count 0) (vla-startundomark adoc) (princ "\nSelect Ellipse") (setq ssnab (ssget '((0 . "ELLIPSE")))) (setq pell (getvar "PELLIPSE")) (setq osm (getvar "OSMODE")) (setvar "OSMODE" 0) (setvar "PELLIPSE" 1) (while (and ssnab (> (sslength ssnab) 0)) (setq el (ssname ssnab 0)) (setq en (vlax-ename->vla-object el)) (setq lay (vla-item lays (vla-get-layer en))) (if (= (vla-get-lock lay) :vlax-true) (progn (vla-put-lock lay :vlax-false) (setq lock (cons lay lock)))) (setq item (vla-get-ObjectName en)) (cond ((= item "AcDbEllipse")(setq count (1+ count)) (setq ptcen (vlax-safearray->list(vlax-variant-value (vla-get-center en)))) (command "_.ellipse" "_C" (trans ptcen 0 1) (trans (mapcar '+ ptcen (vlax-safearray->list(vlax-variant-value (vla-get-MajorAxis en)))) 0 1) (trans (mapcar '+ ptcen (vlax-safearray->list(vlax-variant-value (vla-get-MinorAxis en)))) 0 1)) (mapcar '(lambda (x y)(vlax-put-property (vlax-ename->vla-object (entlast)) x y)) '(Linetype LineWeight Color Layer) (mapcar '(lambda (x)(vlax-get-property en x)) '(Linetype LineWeight Color Layer)) ) (vla-Delete en) ) (t nil) ) (ssdel el ssnab) ) (setvar "PELLIPSE" pell) (setvar "OSMODE" osm) (if lock (foreach x lock (vla-put-lock x :vlax-true))) (vla-endundomark adoc) (princ (strcat "\nTransformation " (itoa count) " Ellipse is completed")) (princ) ) (princ "\nType E2P to run command") PS. Corrected Quote
tzframpton Posted August 8, 2011 Posted August 8, 2011 I'm not sure about a LISP but you can draw them as PLINES in the first place.... PELLIPSE System Variable Type: IntegerSaved in: DrawingInitial value: 0 Controls the ellipse type created with ELLIPSE. 0 Creates a true ellipse object. 1 Creates a polyline representation of an ellipse Man I love the search function on this site. A post made 4.5 years ago just made my day. Quote
VVA1 Posted June 29, 2023 Posted June 29, 2023 Another version. Converts elliptical arcs as well (defun C:E2P (/ adoc el ssnab en item lays lay lock pell pl) ;;; Convert ellipses to polylines (including elliptical arcs) ;;; https://forum.dwg.ru/showthread.php?p=73508#post73508 ;;;https://www.cadtutor.net/forum/topic/597-lisp-for-converting-ellipse-to-polylines/ (vl-load-com) (setq adoc (vla-get-activedocument (vlax-get-acad-object))) (setq lays (vla-get-layers adoc)) (vla-startundomark adoc) (setq ssnab (ssget '((0 . "ELLIPSE")))) (while (and ssnab (> (sslength ssnab) 0) ) (setq el (ssname ssnab 0)) (setq en (vlax-ename->vla-object el)) (setq lay (vla-item lays (vla-get-layer en))) (if (= (vla-get-lock lay) :vlax-true) (progn (vla-put-lock lay :vlax-false) (setq lock (cons lay lock)) )) (setq item (vla-get-ObjectName en)) (cond ((= item "AcDbEllipse") (ace2arcpl en) (mapcar '(lambda (x y) (vlax-put-property (vlax-ename->vla-object (entlast)) x y) ) '(Linetype LineWeight Color Layer) (mapcar '(lambda (x) (vlax-get-property en x) ) '(Linetype LineWeight Color Layer) ) ) (vla-Delete en) ) (t nil) ) (ssdel el ssnab) ) (if lock (foreach x lock (vla-put-lock x :vlax-true)) ) (vla-endundomark adoc) (princ "\nEllipse transformation completed") (princ) ) (defun LM:3ppolyarc ( pt1 pt2 pt3 / ocs ) ;;http://lee-mac.com/3pointarccircle.html (setq ocs '(0 0 1)) (entmakex (list '(000 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") '(090 . 2) '(070 . 0) (cons 038 (caddr pt1)) (cons 010 pt1) (cons 042 (LM:3p->bulge pt1 pt2 pt3)) (cons 010 pt3) (cons 210 ocs) ) ) ) ;;; 3-Points to Bulge - Lee Mac (defun LM:3p->bulge ( pt1 pt2 pt3 ) ((lambda ( a ) (/ (sin a) (cos a))) (/ (+ (- pi (angle pt2 pt1)) (angle pt2 pt3)) 2)) ) (defun NormalAngle (a) ;------------------------------------------- ;; Argument: angle in radians, any number including negative. ;; Returns: normalized angle in radians between zero and (* pi 2) (if (numberp a)(angtof (angtos a 0 14) 0))) (defun TraceACE (obj / startparam endparam anginc delta div inc pt ptlst) ;start and end angles ;circles don't have StartAngle and EndAngle properties. (setq startparam (vlax-curve-getStartParam obj) endparam (vlax-curve-getEndParam obj) anginc (* pi (/ 5.0 180.0)) ) (if (equal endparam (* pi 2) 1e-12) (setq delta endparam) (setq delta (NormalAngle (- endparam startparam))) ) ;Divide delta (included angle) into an equal number of parts. (setq div (1+ (fix (/ delta anginc))) inc (/ delta div) ) ;Or statement allows the last point on an open ellipse ;rather than using (<= startparam endparam) which sometimes ;fails to return the last point. Not sure why. (while (or (< startparam endparam) (equal startparam endparam 1e-12) ) (setq pt (vlax-curve-getPointAtParam obj startparam) ptlst (cons pt ptlst) startparam (+ inc startparam) ) ) (reverse ptlst) ) (defun ace2arcpl ( obj / a ptlst n startparam endparam midpt anab el) (vl-load-com) ;;; Argument: vla-object, an arc, circle or ellipse. ;;; Returns: WCS point list if successful. (setq el (vlax-vla-object->ename obj) ptlst (reverse (TraceACE obj))) (if (and (= (cdr(assoc 0 (entget el))) "ELLIPSE") (zerop(cdr(assoc 41 (entget el)))) (equal (cdr(assoc 42 (entget el))) (* 2 pi) 1e-6) ) (setq ptlst (cdr ptlst)) ;;; Full ellipse ) (setq n 0 anab nil anab (ssadd)) ; anab nil (while (< n (1- (length ptlst))) (setq startparam (vlax-curve-getParamAtPoint obj (nth n ptlst)) endparam (vlax-curve-getParamAtPoint obj (nth (1+ n) ptlst)) midpt (vlax-curve-getPointAtParam obj (+ startparam (/ (- endparam startparam) 2))) ) (setq a (LM:3ppolyarc (nth n ptlst) midpt (nth (1+ n) ptlst))) (ssadd a anab) (setq n (1+ n)) ) (setq a (vl-cmdf "_PEDIT" "_Multiple" anab "" "_Join" 0 "")) (setq anab nil) (princ) (entlast) ) ; _ defun ace2arcpl (princ "\nType E2P in command line")(princ) Quote
Steven P Posted June 29, 2023 Posted June 29, 2023 On 8/8/2011 at 2:57 PM, tzframpton said: Man I love the search function on this site. A post made 4.5 years ago just made my day. Well, your going to love this one..... 1 Quote
