Hi all,
I have written a simple routine to convert "Unicode"s to equivalent "character"s
It is as following:
(defun MT:Conv:Unichar->Char    ;added: 94/12/12
      (%unichar% / *ret*)
(command "_.TEXT" '(0 0) "0.3" "0" %unichar%)
(setq *ret* (cdr (assoc 1 (entget (entlast)))))
(entdel (entlast))
*ret*
Example:
(MT:Conv:Unichar->Char "\\U+0647")    -- returns -->    "ه"
Is there any way to define a function to do the reverse?
I mean, it gets "character" as arguments and returns equivalent "Unicode"?
I appreciate any help or suggestions.:)
  • 1 year later...
Hi,
what if you replace *ret* with (vl-string->list *ret*)? does it return (92 85 43 48 54 52 55) ?
@Ahankhah:
The function MT:CONV:UNICHAR->CHAR doesn't do much... In a roundabout way it merely returns the input string.
(setq a (MT:CONV:UNICHAR->CHAR "\U+0647"))
(setq b "\U+0647")
(= a b) => T
My suggestion for your request:
; (String_To_UniCode "ABC") => "\\U+0041\\U+0042\\U+0043"
(defun String_To_UniCode (str)
 (apply
   'strcat
   (mapcar
     '(lambda (int / hex)
       (setq hex (KGA_Math_Dec_To_Hex int))
       (repeat (- 4 (strlen hex))
         (setq hex (strcat "0" hex))
       (strcat "\\U+" hex)
     (vl-string->list str)
(defun KGA_Math_Dec_To_Base (int base / lst rest)
 (if (zerop int)
   "0"
     (while (> int 0)
       (setq
         rest (rem int base)
         lst (cons (+ rest (if (<= rest 9) 48 55)) lst)
         int (/ int base)
     (vl-list->string lst)
; (KGA_Math_Dec_To_Hex 2147483647) => "7FFFFFFF"
; (KGA_Math_Dec_To_Hex 14285)      => "37CD"
; (KGA_Math_Dec_To_Hex 0)          => "0"
(defun KGA_Math_Dec_To_Hex (int)
 (KGA_Math_Dec_To_Base int 16)
(vl-string->list "ABC") does return (65 66 67). For ASCII characters, it works.
What about international characters?
(vl-string->list "ه") returns (92 85 43 48 54 52 55), which turns out to be \U+0647
And dismayingly, in my dwgcodepage ANSI_936, (vl-string->list "啊") returns (176 161) rather than its unicode which should be \U+554A
@honglog:
It seems that BricsCAD (the program I use) and AutoCAD have a different implementation of vl-string->list and perhaps also of the ascii function.
Some tests with BricsCAD:
(setq a "\U+0647")
(ascii a) => 1607
(vl-string->list a) => (1607)
(String_To_UniCode a) => "\\U+0647"
(setq b "\U+554A")
(ascii b) => 21834
(vl-string->list b) => (21834)
(String_To_UniCode b) => "\\U+554A"
  • 1 year later...
I HAVE A FILE NAME IN UNICODE :(SETQ QFILE "D:\\\U+05D3\U+05D5\U+05E8\U+05D5\U+05DF\\DRAWING3.DWG")
I CAN'T OPEN A NEW FILE
(setq f (open qfile "w")
ttps://www.youtube.com/watch?v=XkczYaBlbNY
Problem displaying Arabic letters on windows - YouTube
hi, you only can write to asciii file, e.g .dxf, txt, csv etc.., but not a drawing file
do you mean open a new drawing?
just curious ac2007
 ([color="blue"]ascii[/color] "\U+6C49") [color="green"];returns only 92 the first char[/color]
just curious ac2007
vlisp return the name of the folder in Unicode ?!?
(setq a (strcat (getvar "dwgprefix")(setvar "dwgname"))) = D:\\\U+05D3\U+05D5\U+05E8\U+05D5\U+05DF\\DRAWING3 .DWG"
because the folder name is in Hebrew : "D:\\דורון\\DRAWING3.DWG"
I found the solution:
