cadartista Posted February 27, 2016 Share Posted February 27, 2016 I open tutorial iARch dwt template and drew my drawing but now i want the size 13x19 instead of the template size 24x36 inches is there an easy way to change the paper size to come out on a 13x19 paper since this is what my printer plots and not a 24x26 inches?? how can I do this? Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 27, 2016 Share Posted February 27, 2016 See the attached image. In either the plot dialog or page set up manager dialog, change the paper size at #1. If you use the plot dialog, be sure to click the button at #2 to save the change to the layout. If your printer only prints one size of paper, the layout should have defaulted to that size. If I may ask, what is 13 x 19 used for? THat is a rather uncommon size of paper. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 29, 2016 Share Posted February 29, 2016 13x19 is for photos/images, my Canon at home does them, they make frames that size, as well as a 18x24 frame with mat for 13x19. If that paper size doesn't show where Dana W indicates, you will need to go to "Properties" button beside the Printer/Plotter (make sure you have selected the correct printer/plotter) and select "Custom Properties" then select the Custom Properties button, the rest depends on options in your printer, but paper size should be there. Quote Link to comment Share on other sites More sharing options...
