gegenytibor Posted February 24, 2016 Share Posted February 24, 2016 Hello guys! I have a block with 6 visibility which I can change easyli with the drop-down list. It works well. But if I change the scale of the block it lose the drop-down list. In the block editor I can see the 6 different states but no drop-down list in the model space. Why? Could you help me? Do you have any ideas? thank you for the answer! T Quote Link to comment Share on other sites More sharing options...
dbroada Posted February 24, 2016 Share Posted February 24, 2016 There was a problem in older versions where the X, Y & Z scales all had to be EXACTLY the same and I found when I scaled blocks the Z scale would be out in about the 6th decimal place. If all three are identical I'm out of ideas. Quote Link to comment Share on other sites More sharing options...
gegenytibor Posted February 24, 2016 Author Share Posted February 24, 2016 Thank you! My problem was: I changed only the X and Y scale and not the Z. If I change all of 3 at the same time it is working well. So need to change all the X,Y and Z scale!!! T Quote Link to comment Share on other sites More sharing options...
dbroada Posted February 25, 2016 Share Posted February 25, 2016 That caught me out a few times too. Quote Link to comment Share on other sites More sharing options...
