CDM-ARCH Posted February 19, 2016 Posted February 19, 2016 I have multiple abbreviations in drawings such as "FA" for first aid and need to have them all oriented in a different direction. Is there a way to select all of them and have them rotate in place or do I need to do each one individually? Quote
ReMark Posted February 19, 2016 Posted February 19, 2016 Is the "FA" in this case text or a block? Quote
CDM-ARCH Posted February 19, 2016 Author Posted February 19, 2016 the "FA" is text with a box around it Quote
ReMark Posted February 19, 2016 Posted February 19, 2016 OK...so we have multiple text objects that we want to rotate. Ah...have you tried the Express Tools command TORIENT? Quote
CDM-ARCH Posted February 19, 2016 Author Posted February 19, 2016 that worked out great thank you Quote
SLW210 Posted February 22, 2016 Posted February 22, 2016 You can also use the properties to change the rotation. Quote
Elvis-Iverson Posted January 5 Posted January 5 TORIENT works if all the text is going to the same angle in the end. What if I have some text that is at different angles and I want them all rotated 180 deg? Quote
