joby1234 Posted February 18, 2016 Posted February 18, 2016 Would anyone have a drawing or hatch similar to this ?? Quote
ReMark Posted February 18, 2016 Posted February 18, 2016 Found this image online. Easy enough to trace over. Not exactly a hatch pattern though. Quote
BIGAL Posted February 19, 2016 Posted February 19, 2016 "laser cut" just google you will find hundreds. Quote
Dana W Posted February 20, 2016 Posted February 20, 2016 I do 'em, but I am expensive, like Madison Avenue expensive. EDIT: WHat is that image, a Lazy Boy showroom? Quote
Dana W Posted February 20, 2016 Posted February 20, 2016 "laser cut" just google you will find hundreds.Don't add "bikini" to that google. Quote
TheCADnoob Posted February 22, 2016 Posted February 22, 2016 i recently had to look for something similar. I found some good starting images looking at .svg and .dxf files that people use with scrap booking cutters. something like http://www.misskatecuttables.com/ there are some good vector images out there already. You do have to be careful of copyright though. Im not sure what the licensing (if any) is needed for larger scale use of these things. Quote
SLW210 Posted February 22, 2016 Posted February 22, 2016 Get a good image and either trace it and fill with a hatch or you can sometimes get good results using Illustrator or Inkscape to trace it, then export to .dwg. Quote
