I have a couple of viewports where I just want to show spot elevations of my surface and not the contours. Whenever I freeze the contours my spot elevations disappear too. When I select a spot elevation it's layer shows as "C-TOPO-TEXT" and when I right-click and go to "Edit Label Style" the label layer is "GRADE-P-T". When I select my contour lines they are on a "C-TOPO" layer, and then when I go to "Edit Surface Style", "Display" tab it shows that the major and minor contours are on "CONTMJR-P-L" and "CONTMNR-P-L" layers respectively. My point being that it seems like they are all on different layers, so I would think I could freeze/thaw the two interchangeably. What am I missing?
Thanks ahead of time!
If the spot elevs are cogo points then use a point lable style this is independent of contour styles.
How are you making the spot elevations.
I have a lisp to label 1 or more individual cogo points as text.
  • 3 weeks later...
I bet that the LISP that BIGAL talked about would be really helpful!
