(command "pedit"lp1"C"ssset)
lp1 is the last entity (pline) added to selection set.
With using above code I can close the all plines which selected.
But I cant exit from the command to go to next step.
Please correct the code.
Pedit ask for single or multi selection option. as you are passing last entity pedit will play with that entity only not with other entities which you are trying to get from ssget.
What exactly you want to do?
You may need to do a loop of each ssset and close
not sure (command "pedit"lp1"C"ssset) (command "pedit" lp1 "C" ssset)
(command "pedit"lp1"J"ssset"""")
(command "pedit"lp1"C"ssset"""")
Upto this position it is ok.I can get closed polyline.
But I cant exit from pedit command. It is repeating.
Even in normal autocad command without using lisp.
We have to press Esc. button to exit pedit command.
Please explane me how can I write a code using vla-put-closed to close the polyline in selection set.
How can I exit from this. Need a lisp code.
(if (setq sset (ssget ":L"'((0 . "*POLYLINE"))))
 (repeat (setq i (sslength sset))
   ([color=blue]vla-put-closed[/color] (vlax-ename->vla-object (ssname sset (setq i (1- i)))) [color=blue]1[/color] )
Better, Post you code to understand its flow and your need according to it
Removed does work , lots of commands require a enter or esc to finish just make sure you have correct "" this may be the problem "" "" note space between.
Edited by BIGAL
Of course if all that's needed is to close all selected polylines just change Close to Yes in Properties.
If you use VL so easy
(setq obj (vlax-ename->vla-object (car (entsel))))
(vla-put-closed obj -1) ; closed pline
(val-get-closed obj) ; it returns 0 if it is open
