Drolma
I have forgotten the syntax to query a setq statement at the command line in autocad. I used to type a setq PT1 at the command line and the value was returned. But I cannot remember the trick to doing this. Can anyone help.
Thanks
At the AutoCAD command-line:
Command: (setq myvar 123)
123
Command: !myvar
123
Using the VLIDE console is much easier:
_$ (setq myvar 123)
123
_$ myvar
123
Thanks
first check if TEXTEVAL is on (1) and then you could use someting like !Pt1 or (eval pt1) or just pt1 , depending in what manner you want to retrieve your point.
Gr. Rlx
