miles150 Posted January 28, 2016 Posted January 28, 2016 where can I find the .lisp that will detail a spiral stair? Quote
ReMark Posted January 28, 2016 Posted January 28, 2016 This thread is six years old. If someone had a lisp routine that could automatically create a spiral stair I think they would have posted it by now. Were you looking to create it in 2D or 3D? Quote
BIGAL Posted January 29, 2016 Posted January 29, 2016 (edited) Yes there is a lisp but its a bit of a cheat as it was done for a demo, back to the spiral though all you need is to draw 1 tread in full 3d then just simply copy & rotate then move to correct z. The code was done in 1991 I need to add a helix option now so the hand rail will be correct. Edited January 29, 2016 by BIGAL Quote
Bill Tillman Posted January 29, 2016 Posted January 29, 2016 Unless you're doing some very repetitive, I'd skip LISP and just layout your stairs. Whether it's 2D or 3D, a LISP program to do spiral stairs is not an easy undertaking. But if you've got the time, then go for it. Just did a quick google search and the topic is covered out there as well as in this forum. Here is one that should get you started. Quote
SLW210 Posted January 29, 2016 Posted January 29, 2016 I moved the posts to the AutoLISP, Visual LISP & DCL Forum for you. Quote
BIGAL Posted January 29, 2016 Posted January 29, 2016 LISP program to do spiral stairs is not an easy undertakingSorry Bill to produce the 3d image I posted is 18 lines of code. Helix was not available at the time of writing 1991. Will have a look at your post link. Quote
