TJKawaguchi Posted January 27, 2016 Share Posted January 27, 2016 I have a rectangular device tag with polylines as wires. I want to rotate the wires, but since the device is rectangular, I end up with spaces at 90 and 180 degrees. Any suggestions would be greatly appreciated. Motion Detector.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 28, 2016 Share Posted January 28, 2016 Couldn't you solve the problem using visibility states? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted January 28, 2016 Share Posted January 28, 2016 Couldn't you solve the problem using visibility states? That certainly sounds like one way to go. Quote Link to comment Share on other sites More sharing options...
steven-g Posted January 28, 2016 Share Posted January 28, 2016 A visibility action is probably the easiest, but you can also do it using a rotation linked to a point parameter, and then controled by a lookup. Motion Detector(1).dwg Quote Link to comment Share on other sites More sharing options...
ayethzerothree Posted February 2, 2016 Share Posted February 2, 2016 how about using polar stretch. I think this is the easiest way Quote Link to comment Share on other sites More sharing options...
TJKawaguchi Posted February 11, 2016 Author Share Posted February 11, 2016 Polar stretch with a distance list was the answer. Device Block with Poly Rotation.dwg Quote Link to comment Share on other sites More sharing options...
TJKawaguchi Posted February 15, 2016 Author Share Posted February 15, 2016 The DWG above works. But, now I need to recreate it with MText instead of an attribute and I can't remember how I did it. Quote Link to comment Share on other sites More sharing options...
