Someone knows the ability to create multiple lines across intersections?
Break at point using a circle, now where did I put it, manual is circle at Int, trim pick circle pick inside. Sure it exists others may have code its a common request.
Ps download a screen grab program like Gadwin. Snipit etc. Then can get just a little bit of screen. I had to look real hard to see what you wanted.
