Dragspelarn Posted January 15, 2016 Share Posted January 15, 2016 Hello Folks! Having problems with the UCS at the moment. I have rotated my drawings with the UCS command and used the plan command to set the drawings in the angle i want to view them in. And then used world to get the co-ordinate system true to its original state. The problem is when i am trying to attach the drawings together, they are in different places. Do you guys have any clues? (Sorry for my bad english) /Per-Anton Quote Link to comment Share on other sites More sharing options...
dkeran Posted January 15, 2016 Share Posted January 15, 2016 Possible check the xrefs you are attaching to see if they are in the same co-ordinate system and scale that your main drawing is in? Quote Link to comment Share on other sites More sharing options...
halam Posted January 15, 2016 Share Posted January 15, 2016 Or. Check INSBASE for insertion point of dwg xref (check both, should be 0,0,0).. Quote Link to comment Share on other sites More sharing options...
