engmech Posted January 14, 2016 Posted January 14, 2016 Hello! I have dynamic block with two parametr - "a" and "b". I need to att "A" keep the value "a" and att "A" will be not editable. Is that possible? Quote
engmech Posted January 18, 2016 Author Posted January 18, 2016 Thank you! I use this tutorial http://www.ellenfinkelstein.com/acadblog/tutorial-use-fields-to-automatically-label-dynamic-blocks/ and I found solution how to link parametr "a" with attribute "A". But the formula for the area att "S" is still not calculated. In value "S" displayed for example 60*60, but I needs value 3600. Mode "Closed" will not work, because I need to attribute value is displayed in the properties. As I understand attribute can not be done, to together display the attribute in the properties and would not editable. column2.dwg Quote
SLW210 Posted January 21, 2016 Posted January 21, 2016 You need to select Area as value of S, not a*b. Maybe go back through the tutorial. Quote
engmech Posted January 22, 2016 Author Posted January 22, 2016 "You need to select Area as value of S, not a*b" It works, thank you. Quote
