Is programmatically possible to know if there's a hatch inside a closed 2dpolyline?
  • Replies 28
  • CesarA
    12
  • CadFrank
    9
  • Tharwat
    5
  • Lee Mac
    3
Hi,
Well the best thing to do is to close your 2d polyline :P
LOL.. i'll be damned.. Yes, I meant a closed 2dpolyline.. and what after it?
Well you would need to select the area.. is it because your hatch scale is not good?
If you just made a hatch and you dont see it, it's because your 2d polyline isn't really closed.
Look in Pedit to make sure
Not really, what I wanna do is select a bunch of closed polylines, like these:
And I wanna fill those who have no hatch.
Oh!! well that's a hard one! but using select similar it should help, then you'd be able to unselect using shift the ones that have a hatch.. thats how i'd do it.
Hi,
Just retrieve the coordinate points of each polyline then use the function ssget with mode string "_CP" or "_WP" with filter to hatch objects only and you'd be there. :)
But in that case you are assuming the empty ones have the same dimensions.. well.. they don't :\
Thanks tharwat, I'll study the case. Did you see anyone implement such code?
Not sure he know Autolisp Programming :P
your best option with no programming is select similar.. or else well it's to deep for my knowledge of Autolisp
But Frank, there's a reason i'm posting this in a programming section :P thanks anyway :)
I figured you had one :D
Well no problem wasnt much help :P
I don't need to see.
:lol:
Have a play with this simple and quickie one.
(defun c:test (/ ss i sn)
 (if (setq ss (ssget '((0 . "LWPOLYLINE"))))
     (if (ssget "_CP"
                       (mapcar 'cdr
                               (vl-remove-if-not
                                 '(lambda (p) (= (car p) 10))
                                 (entget (setq sn (ssname ss (setq i (1- i)))))
                       '((0 . "HATCH"))
       (ssdel sn ss)
 (sssetfirst nil ss)
Edited by Tharwat
Don't want to give you any disrespect Tharwat. I think he wants the code to do this.. :D
But nice work !!
(defun c:test (/ ss i s sn)
     (if (setq s
                     (ssget
                       "_CP"
                       (mapcar 'cdr
                               (vl-remove-if-not
                       '((0 . "HATCH"))
       (ssdel sn ss)
 (sssetfirst nil ss)
I juste removed the not on the 4th line :D
Cheers.
But nice work !!
Cheers.
Thank you Frank , you are right. ;)
