Wallisthfc Posted January 13, 2016 Share Posted January 13, 2016 Hi I am currently using Autocad 2015 LT in as a freelance in someones office. We tend to hatch our building outlines in grey solid but when we print the grey comes out as purple. I've been inside the network settings and adjust all sensible options but unfortunately it is still coming out as purple. I assume that the issue is with the plotting settings from the workstation but have limited fire fighting experience with plotting. Please help! Plotter is a Cannon IP760, i have plotted the same drawing from several workstations and altered the screening/ pen styles and in a different version of AutoCAD (2010) which leads me to think the issue is applied to the layout of the drawing of the plotter setting on the network. Any suggestions would be gratefully received Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 13, 2016 Share Posted January 13, 2016 Did you check the plot style that you are using to see if the normal grey color was overridden? What plot style is being used? Ex. - acad.ctb Quote Link to comment Share on other sites More sharing options...
Wallisthfc Posted January 13, 2016 Author Share Posted January 13, 2016 Ive tried None, acad.cbt, 100% screening, 25% screening. i will try to see if it is overwritten now. fingers crossed. Quote Link to comment Share on other sites More sharing options...
Wallisthfc Posted January 13, 2016 Author Share Posted January 13, 2016 All seems fine. The layer settings is set to print colour 252 as 252 also. Quote Link to comment Share on other sites More sharing options...
Wallisthfc Posted January 13, 2016 Author Share Posted January 13, 2016 no change basically Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 13, 2016 Share Posted January 13, 2016 We have a Canon iPF760. I'd be willing to do a test print if you don't mind sharing the drawing. Don't need the whole drawing just enough to troubleshoot the problem. I assume you really do want this plotted in color is that correct? Quote Link to comment Share on other sites More sharing options...
Wallisthfc Posted January 13, 2016 Author Share Posted January 13, 2016 (edited) perfect. how do i send you the file? here is my email Yes it will print in colour but unfortunately the grey is upside down Edited January 13, 2016 by Wallisthfc Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 13, 2016 Share Posted January 13, 2016 (edited) All we are interested in is getting the grey to plot in the correct color. It could be upside down and backwards for that matter. I just sent you an email. When it arrives you might want to edit out your email address in the above post. Update: Turns out the solid hatch used in the plan views was on a different layer and assigned a different shade of grey than that used in the elevation views. OP said he knew how to fix the problem. Edited January 13, 2016 by ReMark Quote Link to comment Share on other sites More sharing options...
