Ramana Posted January 8, 2016 Posted January 8, 2016 Dear Friends, Greetings! Happy New year to all friends! I am working on documentation part for a developing Coordinated shop drawings, I am unable to get the bottom of pipe. Can any one help he in creating or sample file for the same. Ramana Quote
tzframpton Posted January 8, 2016 Posted January 8, 2016 This is always a confusing approach for Revit MEP users. Everyone, when beginning in Revit, thinks to use a Tag first. Don't use a Tag, use the Spot Elevation Tool instead. You're restricted on formatting, but it certainly can be customized, and it gives you options for anchoring to the Center of pipe, Top or Bottom of pipe, or both TOP/BOP. Type EL to initiate the Elevation Tool, then on the Ribbon Modify Bar look for the "Display Elevations" drop down for the COP/TOP/BOP options. -TZ Quote
