As we say here in NL : garantie tot aan de deur
I've updated RlxPaste in attempt to handle dynamic blocks a little different than the normal cut/copy stuff.
At this time it only works (if it works at all) when you select 1 dynamic block to add.
It checks if block is dynamic or not. If so , it reads all dymanic properties of this block (I nicked a couple of Grand Master Lee's routines but don't tell him 😉  )
Save the block (under a different name of course because you can't save a block with the same name as the dwg)
Then it writes all properties to a text file in the same folder & same name as the block but with extenion dbd (dynamic block data).
Theory is that after insert it reads this dbd file and puts all props back. If it works , oh happy day , if it doesn't this conversation never happend...
RlxPaste.LSPFetching info...
Edited by rlx
little bug removed, check worked but 'normal' mode stopped working
  • Like 2
