rlx Posted March 15 Author Posted March 15 (edited) As we say here in NL : garantie tot aan de deur I've updated RlxPaste in attempt to handle dynamic blocks a little different than the normal cut/copy stuff. At this time it only works (if it works at all) when you select 1 dynamic block to add. It checks if block is dynamic or not. If so , it reads all dymanic properties of this block (I nicked a couple of Grand Master Lee's routines but don't tell him ) Save the block (under a different name of course because you can't save a block with the same name as the dwg) Then it writes all properties to a text file in the same folder & same name as the block but with extenion dbd (dynamic block data). Theory is that after insert it reads this dbd file and puts all props back. If it works , oh happy day , if it doesn't this conversation never happend... RlxPaste.LSPFetching info... Edited March 16 by rlx little bug removed, check worked but 'normal' mode stopped working 2 Quote
