61metsj373 Posted December 30, 2015 Posted December 30, 2015 Hey guys, I currently am using a Carlson SurvCE data collector and have collected a series of points (Northing/Easting) and (Latitude/Longitude). When I import the points and create a table to display the Northing/Eastings in Lat/Long format, Autocad Civil 3D gives me different values then the SurvCe data collector shows. If I were to plot these Lat/Long points that Autocad calculates from the Northing/Easting they not accurate at all. My Northing/Eastings plots precise but the generated Lat/Long do not. ?? Quote
Organic Posted January 2, 2016 Posted January 2, 2016 https://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Civil3D-UserGuide/files/GUID-A68DFB6F-6BE3-4719-8A1E-2D4FF1E53219-htm.html https://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Civil3D-UserGuide/files/GUID-A2C0D8F7-0BCF-46F6-8A0E-217834AF136B-htm.html Check that they are setup correctly for where in the world the data was captured. My guess would be Carlson is setup correctly for you (and hence why works) and Civil 3D is not. Quote
