WPerciful Posted December 28, 2015 Posted December 28, 2015 I’m in the process of updating nearly 400 blocks. I have to change the layer and override the color of one attribute. My test on the first block failed. It's just been a while and I can't remember what I'm missing. My attempt for changing the first one: (progn (setq e (car (entsel )) d (entget e) n_e (entnext e) n_d (entget n_e))) un_d (subst (cons 8 "SYM") (assoc 8 n_d) n_d) un_d (append un_d (list un_d (cons 62 141))) ) (entmod un_d) (entupd (cdr (assoc 330 un_d))) ) I've also tried: (command "_.attsync" "_select" n_e "" )"_Yes") note: as I step through the block entities I will be testing to insure I've got the right block with: (and (= (cdr (assoc 0 n_d)) "ATTRIB") (= (cdr (assoc 2 n_d)) "SIZE") (/= (cdr (assoc 8 n_d)) "SYM") ) Quote
BIGAL Posted December 28, 2015 Posted December 28, 2015 If you only want to change 1 block using name no matter where the block is maybe use block edit, BEDIT this will update all. I would use VL code its a bit easier using get & put to change stuff. You should post a dwg with this block. 1 Quote
WPerciful Posted December 28, 2015 Author Posted December 28, 2015 I'm getting closer to what I need with the code below. If I double click on the block, the attribute layer has been updated. But when I check the block defination it remains unchanged. The commented out attsyncs didn't resolve the issue. (progn (defun get_ents ( ss / ents ss1 l cnt) (setq ents (list ) ss1 ss l (sslength ss1) cnt 0 ) (while (< cnt l) (setq ent (ssname ss1 cnt) ents (append ents (list ent)) cnt (1+ cnt) ) ) ents ) (setq ss01 (ssget "x" (list (cons 0 "INSERT"))) ents (get_ents ss01) ) (foreach line ents (setq head_e line head_d (entget head_e) name (cdr (assoc 2 head_d)) ) (if (cdr (assoc 66 head_d)) (progn (setq e (entnext head_e) d (entget e) ) (if (and (= (cdr (assoc 0 d)) "ATTRIB") (= (cdr (assoc 2 d)) "SIZE") (/= (cdr (assoc 8 d)) "SYM") ) (progn (setq d (subst (cons 8 "SYM")(assoc 8 d) d)) (entmod d) (entupd (cdr (assoc 330 d))) (entupd (cdr (last (tblsearch "block" name)))) ;(command "_attsync" "S" (cdr (last (tblsearch "block" name))) "Y") ;(command "_attsync" "S" head_e "Y") ) ) ) ) ) ) Quote
WPerciful Posted December 28, 2015 Author Posted December 28, 2015 BIGAL, I don't have a lot of ex with VL. I have about 400 different blocks that each need to have the same update, so I'm not sure that bedit will work here. But I'll look into it. Thank you. -- I attached a file with three of the blocks that I need to update. demo.dwg Quote
Lee Mac Posted December 28, 2015 Posted December 28, 2015 Try the following: (defun c:fixatts ( / d e i s x ) (while (setq d (tblnext "block" (null d))) (if (= 2 (logand 2 (cdr (assoc 70 d)))) (progn (setq e (tblobjname "block" (cdr (assoc 2 d)))) (while (setq e (entnext e)) (if (and (setq x (entget e)) (= "ATTDEF" (cdr (assoc 0 x))) (= "SIZE" (cdr (assoc 2 x))) ) (entmod (cons (cons -1 e) '((8 . "SYM") (62 . 141)))) ) ) ) ) ) (if (setq s (ssget "_X" '((0 . "INSERT") (66 . 1)))) (repeat (setq i (sslength s)) (setq e (entnext (ssname s (setq i (1- i)))) x (entget e) ) (while (= "ATTRIB" (cdr (assoc 0 x))) (if (= "SIZE" (cdr (assoc 2 x))) (entmod (cons (cons -1 e) '((8 . "SYM") (62 . 141)))) ) (setq e (entnext e) x (entget e) ) ) ) ) (princ) ) The second half of the code could be replaced by a call to ATTSYNC, but bear in mind that such a call would cause the properties of all attributes to revert to those defined in the block definition, which may be undesirable. 2 Quote
WPerciful Posted December 29, 2015 Author Posted December 29, 2015 Brilliant!! Doeseverything I need! Thank you Sir, you’re awesome! Quote
Lee Mac Posted December 30, 2015 Posted December 30, 2015 Excellent to hear - thank you for your compliments! Quote
imoze Posted October 14, 2022 Posted October 14, 2022 Thank's a lot for that code you save me from a lot of pain. Quote
