addesigns Posted December 21, 2015 Posted December 21, 2015 Is there a way to make a 2d view not show the 2d lines when i have a concrete column next to a wall that is the same height? Realistically if they are the same elevation you would not see a line between the 2 elements. I know you cant join them since they are 2 different elements but is there a way to make them look like the are one pour? Im not looking to override it with invisible line since you have to afterwards draw a 2d line because it will hide that whole edge. Im not looking to do a masking region either. If anyone has a solution or answer to this do tell. Quote
tzframpton Posted December 22, 2015 Posted December 22, 2015 They should be able to join, especially if you use a Column Category and not the Structural Column Category. The regular Column Category is an architectural column and will join to a wall. Quote
