stevedrew Posted December 15, 2015 Posted December 15, 2015 (edited) Ran as administrator, installed the Foxit Reader to use with C3D & LDD and it worked well for a long period of time. However, at some point in time, while selecting during plot it started crashing the entire program and ended. Application Programs: AutoCAD Civil 3D Land Desktop Companion 2009 AutoCAD Civil 3D 2009 Platform: Windows 7 I have: Uninstalled and reinstalled Foxit Reader. Applied local repair to both C3D & LDD None of these worked. I have searched the web attempting to find someone else who have had this problem but did not find any significant hits. Also, if there is a comparable PDF driver for AutoCAD plotting to PDF, that would be helpful. Would appreciate any help or suggestions. Thanks in advance... Edited December 15, 2015 by stevedrew Quote
Emigrato Posted December 16, 2015 Posted December 16, 2015 if there is a comparable PDF driver for AutoCAD plotting to PDF, that would be helpful Without any doubts, go with CutePDF, sir. Quote
stevedrew Posted December 16, 2015 Author Posted December 16, 2015 Thanks Emigrato! I downloaded and installed CutePDF, however during plot output it did not prompt me for folder/filename. Is there a setting I am missing? Thanks Quote
stevedrew Posted December 16, 2015 Author Posted December 16, 2015 Actually, after searching background windows I discovered the saveas box. It doesn't pop-up to front... Will it work well using the publisher? Quote
